Inventor Nesting - Part imported wrong side up
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
A colleague and I are trying to solve an issue happening with Inventor Nesting. We start with a multi body part and make our assembly from that. Our parts have mills and pilots in them they have to be cut with specific faces facing up so after adding all the details to the parts we make an assembly and place all the parts in the assembly with the face we want up facing Front. We then Create a Nest using that assembly. When looking at the 2D view of the source files in the Nesting Add-In everything looks fine but if you switch over to the 3D Detailed view you can clearly see that the part was brought in with the wrong side facing front so after we do the nesting study we do a 3D Extrude on the nested sheet and when it uses the original part for the 3D model it is flipped back side to front. We have tried just about everything we can think of to force it to pull the part in with the correct orientation but nothing seems to be working. We have even tried the Nest Authoring using an unconsumed sketch as the last item in the design tree but it still pulls the part in upside down. Does anyone know a work around or a way to force which face is chosen to be up when the part is derived from an assembly made from a multi-body part?
