Inventor Nesting fails to import iParts (Internal COM Error)
A3XXFR
A3XXFR
I have been trying to get inventor nesting to import an assemble for the better part of the past 5 or so hours. Initially when I tried to import the assembly, the utility would think for about 5-10min then spit out nothing. The nesting tab wouldn't show any geometry sources. No errors or warnings. Nothing. I tried many things like deleting bolts and anything that wasn't sheet metal to try and get it to work.
Eventually I went back to an old nesting file I had made with an earlier version the assembly. Here when I tried to refresh the nest the program actually gave an error: Reload Error: Internal COM Error. I little more digging and it seems this error is only on iParts (The table that generates files). I have also tried importing the iPart directly into a new nesting file and the issue persists. Is this a limitation of the software? Can we not use iParts? If not how can the issue be resolved?
I have attached a screenshot of the message and one example of the offending files (Master file and generated Files). Using Inventor 2021 + Nesting Utility 2021.
Thank you for your help in advance.
Revit 2021, 2022, AutoCAD 2018, Inventor 2021
Specs:
AMD Ryzen 5900X, Nvidia RTX3080, 32GB RAM
ToddHarris7556
It's a late reply, but I'm up against the same issue.
iPart factory contains (8) members, and I'd just like to use these to do nest layouts -
(48) of iPartmember1
(36) of iPartmember2
(24) of iPartmember3
etc.
I did see another (older) thread that suggested maybe adding a key to the factory. I did that and still get the Internal COM error. No import.
Any thoughts appreciated!
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
bopttopb_1973
I'm having the same issue. Still doesn't seem to be resolved
hansDPQMN
its stille there inventor 2024
ray.marson
The part file needs to have a Flat Pattern created to be able to nest it.
