Inventor Nesting fails to import iParts (Internal COM Error)
- Mute
- Permalink
- Report
I have been trying to get inventor nesting to import an assemble for the better part of the past 5 or so hours. Initially when I tried to import the assembly, the utility would think for about 5-10min then spit out nothing. The nesting tab wouldn't show any geometry sources. No errors or warnings. Nothing. I tried many things like deleting bolts and anything that wasn't sheet metal to try and get it to work.
Eventually I went back to an old nesting file I had made with an earlier version the assembly. Here when I tried to refresh the nest the program actually gave an error: Reload Error: Internal COM Error. I little more digging and it seems this error is only on iParts (The table that generates files). I have also tried importing the iPart directly into a new nesting file and the issue persists. Is this a limitation of the software? Can we not use iParts? If not how can the issue be resolved?
I have attached a screenshot of the message and one example of the offending files (Master file and generated Files). Using Inventor 2021 + Nesting Utility 2021.
Thank you for your help in advance.
Revit 2021, 2022, AutoCAD 2018, Inventor 2021
Specs:
AMD Ryzen 5900X, Nvidia RTX3080, 32GB RAM
