Inventor Nesting 2022: how do I fix not being able to add Vault source files?
fridtjofZM5ME
Message 1 of 10
fridtjofZM5ME
I keep getting this error whenever I try to add source files from Vault in Inventor Nesting. Is this a server issue, Vault issue, or an issue with nesting add-in itself?
Replies (9)
Message 2 of 10
bradeneuropeArthur
Take a look here:
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
fridtjofZM5ME
Hmm, that's a little weird... Fetching Vault files in ANY context is part of Vaults core funcionality, and it DID work a couple of annual releases earlier. That Autodesk all of a sudden should concider that to be a "DeLuxe-feature" and restrict it to the top-shelf version of Vault would be a bit unbecoming of them when the method worked with Vault Basic earlier...
Message 4 of 10
bradeneuropeArthur
@johnsonshiue
Do you have an explanation for this!
There must/may be a good reason for, isn't it!?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
johnsonshiue
Hi Folks,
I am sorry I am not aware of the issue. I need to contact the project team.
Many thanks!
Software Test Engineer
Message 6 of 10
fridtjofZM5ME
@johnsonshiueTell them to feel free to contact me if they need to see it on my particular system, should the error not be reproducible on their end.
Message 7 of 10
MattWynn
We are working with the different teams.
@fridtjofZM5ME What version of vault and what version of Inventor Nesting are you using?  Was this working for you before?  Have you updated either of them recently?
Matt Wynn
Senior Manager, Software Development, Fusion Fabrication
Message 8 of 10
fridtjofZM5ME
Hi @MattWynn I'm currently using Vault Basic 2022.0.1 and Inventor Professional 2022.0.1.
I've been using Inventor and Vault together since mid 2018 (meaning since Inventor 2019) and adding source files from Vault in the nesting environment worked from then up until some time last fall I think (maybe earlier). It stopped working some time ago, but I didn't find it bothersome until recently. The nesting environment was actually the main reason we got the PD&M package to begin with.
Regarding updates, I tend to do them as soon as they are available to me through the Autodesk Desktop App. I also do Windows updates regularly, but it doesen't feel like that is to blame in this particular case.
Message 9 of 10
AmyLiu
Hi @fridtjofZM5ME
thanks for the information, we could finally reproduce the issue you met. working in progress to check the reason and back to you ASAP.
Amy Liu ([email protected])
Senior Software QA Engineer
Message 10 of 10
fridtjofZM5ME
@AmyLiuThank you, looking foreward to a resolution for the problem.
