@elaine.chan wrote:
But all my part files & assemblies must be in the same folder in order to open the assembly file properly?
I've many assemblies, some assemblies contains sub-assembly files
Short answer:
No, drawing, part and assembly can be in any folder.
Long answer:
Everything needs to be in same folder as 'Workspace'.
Drawings best keep with ipt, iam, ipn in same folder.
For me:
Workspace - C:\Jobs 2018
Then inside with customers -
\Customer 1
\Customer 2
So the full path is -
C:\Jobs 2018\Customer 1
C:\Jobs 2018\Customer 2
Then job number inside Customer -
\0001
\0002
Full path -
C:\Jobs 2018\Customer 1\0001
C:\Jobs 2018\Customer 1\0002
C:\Jobs 2018\Customer 2\0003
C:\Jobs 2018\Customer 2\0004
There could be common parts and hardwares -
\Common Part
\Hardware
Full path -
C:\Jobs 2018\Common Part
C:\Jobs 2018\Hardware
Parts and assemblies can be in any of those folders and used by any assemblies.
I've seen other with folders for drawing, part and assembly.
How to manage them is your problem and a company 'standard'.
There is no right or wrong, whatever works for you.
Now Pack n Go.
Use it only to collect everything and send to customer.
You can Pack n Go keeping folder structure and you SHOULD.
My setup result in very similar structure after Pack n Go.
Best is to try different setup and see how you like it and adjust as you go.
Took me a few years and lots of trial and error to get what I'm using now.
