Ctrl+Tab switching order (recently used order)
j.pavlicek
Message 1 of 10
j.pavlicek
is somehow possible to switch ctrl+tab switching order? I'm used to use this shortcut like Alt+tab in windows - switch between recently used tabs, but Inventor is cycling from left to right.
(Yes, I know that I can move tabs next each other and use ctrl+tab and ctrl+shift+tab, but this is so workflow destroying.)
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Replies (9)
Message 2 of 10
Sergio.Bertino
Autodesk Support
Autodesk Support
Hello @j.pavlicek
Thanks for your post.
The combination ctrl+tab is not a native functionality in Inventor, you can use it for most of the Windows applications with multiple documents opened.
I don't think is possible to change the order.
Sergio Bertino
MFG Technical Support Specialist
Message 3 of 10
Cadmanto
The only place in Inventor you can program hot keys is here.
BUT, since this is a MS key stroke, I strongly advise against it.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 10
Sergio.Bertino
Autodesk Support
Autodesk Support
Hello @j.pavlicek,
I am checking back to see if our posts helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Sergio Bertino
Message 5 of 10
j.pavlicek
If it is Windows provided function then OK. Thanks.
But definetly it is possible (to implement this function). Because I'm used to use it this way at least in web browser since 2005 (Opera, Maxthon, Vivaldi).
Maybe topic for Ideastation.
Message 6 of 10
Mitchellduhe
Coming from Solidworks, they have a good window navigation functionality. Ctrl+Tab opens a small overlay of your most recently opened files, very similar to Alt+Tab on windows.
Has this been updated in recent versions of Inventor?
Message 7 of 10
KDeLuciaE4M82
Community Visitor
Community Visitor
Still not fixed and its now 2025.  Maybe inventor will add the option.  Or maybe I should switch my team to solidworks.
Message 8 of 10
johnsonshiue
Hi! I am not familiar with the exact workflow in SWX. But Inventor Ctrl+tab cycles through the currently opened documents. Is this what you are looking for?
Many thanks!
Software Test Engineer
Message 9 of 10
Cadmanto
In Solidworks you can cycle through the open models using the control+tab.  I use it all the time.
With Inventor, the models have a tab you can select at the bottom of the model window.  I actually found that easier to use and quicker then the control+tab.
Best Regards,
Scott McFadden
Message 10 of 10
Mitchellduhe
My issue with the ctrl+tab functionality in Inventor comes when I have many parts open, specifically parts that have long ID numbers as file names. I have no idea which part on the bottom of the screen is the one I was just working on. This is specifically frustrating when the number of tabs exceeds the window width and I cannot see all the tabs.
There is *almost* a good substitute in the hamburger menu at the bottom right. That opens a list of the open parts that you can hover over and see a preview of the part.
A keyboard shortcut that displays a preview of all the open documents (just like alt+tab in windows) would allow quick navigation between files without cycling through each file.
Also, the ctrl+tab will cycle to the home tab, which I wish I could close.
