Custom Material Library and Color Library Keep going missing
aky
aky
Hello
I have a custom material & color library file in folder
C:\Users\Public\Documents\Autodesk\Inventor 2019\Design Data\Material
"custom.Color.adsklib"
"custom.Material.adsklib"
But each time I open a file, inventor asks me to locate these files.
My file option is set to "C:\Users\Public\Documents\Autodesk\Inventor 2019\Design Data'.
How do I get inventor to recognize the custom library right away?
Thank you.
johnsonshiue
Hi! Are these two libraries included in the project settings? Close all documents. Go to Get Started -> Project -> Material Library -> make sure the libraries are included there -> repeat the process for Appearance Library.
Many thanks!
Software Test Engineer
Define/Set them in you project file
kelly.young has embedded your image for clarity.
aky
For some reason it stopped recognizing the library so I removed the library in the project setting and repeated the setting library process again. Now it works! Thanks.
