Inventor issues - performance
NachoShaw
Advisor Advisor
NachoShaw
Hey
anyone else experiencing inventor issues? My current version 2022.2 is super slow. it takes 20 seconds to get a new file dialog, 5 minutes to create a new empty file, 15-20 minutes to open a basemodel....
I went to run a repair and the option is no longer there. so the only option now is to completely uninstall inventor and then re-install it?
What happened to the repair option?
what happened to the performance?
FYI, im working local, not on a network, all of my drivers are up to date
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
bradeneuropeArthur
could you send the ipj file you are using?
could you make a screenshot from the application options File Tab?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
johnsonshiue
Hi! The behavior does not sound right to me. Make sure all critical Windows updates are installed and graphics driver is updated.
Where are the \Design Data\ files stored?
Clean up %temp%
How many projects do you have listed on Project dialog? Does the active project reference some library or favorite folders no longer available? If possible, please take a snapshot of the project dialog and send it to me directly johnson.shiue@autodesk.com.
Many thanks!
Software Test Engineer
