Inventor is trying to check in ANYCAD files that don't exist
michael.harbove
michael.harbove
We recently upgraded to Inventor 2023 from Inventor 2020.
I have an assembly that lives int eh vault that is composed of two files, both of which are multibodied parts.  These multibody parts were created using the import command and using the Reference Model option (there was a chance the model we were importing could change).  Trying to check the file into Vault Workgroup 2023, it wants to check in files that don't exist.  The two components int he assembly that the Reference Model process was used on are already checked back into the Vault, for some reason Inventor is trying to create/reference components that don't exist in a path that isn't used.  Our Vault work folder lives on a separate drive that is not C.  This is preventing us from checking the file back in.  Any help on this is appreciated and is urgent for us to get something to our customer on time.
johnsonshiue
Hi! It is a bit hard to tell what is happening from an image. Let me ask a few questions. You mentioned that these AnyCAD files don't exist. But, you also mentioned that the multi-solid body parts were linked at a point. Could you share an example what exhibits the problem?
Many thanks!
Software Test Engineer
michael.harbove
I will try and summarize.
BACKGROUND:
We got STEP files from a vendor of equipment we are integrating in a design. Because I knew there was a chance the models may change (and now they are going to), I decided to use the REFERENECE MODEL option when importing the STEP file rather than converting it to multiple bodies/parts. I used the IMPORT function after starting a new part for the process since the STEP file of the assembly does not need to be an assembly for my purposes. When checking the newly created part into the Vault, it checks in as a single part as expected. I suppressed the link to the model in the part so it is not always referencing the STEP file and checked the STEP file into the Vault also.
I performed this process twice for two different assemblies from the vendor and combined them into a single assembly with a PURCHASED BOM structure.
CURRENT ISSUE:
The problem that is occurring did not show up in the 2020 version of the software.
What I am trying to do now is check in the assembly that combined the two components (the two parts from imported, REFERNECE MODEL, geometry). When trying to check in the parent assembly, it is telling me it would need to check in a bunch of other components that don’t exist. What the screenshot shows is parts that would have normally been generated if I imported the STEP file as a regular Inventor assembly. But these parts don’t exist: 1) I imported the STEP file into a part and did not use the open command, which would have made a multi body part; and 2) I was able to check the new components from the imports into the Vault without the software asking me to check said parts.
The software thinks these non-existent parts are also in my Documents folder on the C drive when my Vault controlled Inventor project file (which is active in Inventor) points to a separate drive entirely.
johnsonshiue
Hi Michael,
I suspect the iam file may have corrupted references. If possible, please share the iam and ipt files with me directly [email protected]. I can use our internal debug tool to tell if such corrupted references exist.
Many thanks!
