Inventor: How to simulate a crop circle closing when pressed
creocatia3d
Message 1 of 19
creocatia3d
how can I simulate a crop circle closing when pressed? Type to push a mug
@creocatia3d,
marius.gildehaus has edited your subject line and embedded pictures for clarity
Original: Circle closing when pressed
Replies (18)
Message 2 of 19
johnsonshiue
Hi! Strictly speaking, I don't think Inventor can simulate such deformation. It is because the deformation will require progressive change in radius, assuming there is no stretching or contraction.
If you just want to fake it by closing the gap gradually at a constant radius, it may be doable using Drive constraint and Adaptive.
Many thanks!
Software Test Engineer
Message 3 of 19
j.palmeL29YX
You can create an animation in Inventor Studio, as attached.
cadder
Jürgen Palme
Message 4 of 19
creocatia3d
show!!!
but you can do it with only one part instead of the two ends at the same time
Message 5 of 19
JDMather
@creocatia3d wrote:
show!!!
I do not understand what this response means?
Can you Attach your file(s) here?
The general principle is to Animate Parameters - you can adapt the general principle to  whatever conditions you need.  Can  you provide more information on your Design Intent?
Message 6 of 19
j.palmeL29YX
Of course, yes. You only need to fix one side. (If I understand you right).
Attached two other variations.
cadder
Jürgen Palme
Message 7 of 19
marius.gildehaus
Hello @creocatia3d!
Does the example from @j.palmeL29YX answer your question?
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Thanks!
Marius Gildehaus
Technical Sales Specialist
Message 8 of 19
creocatia3d
friend, simulate in the presentation is perfect. But I would like to realize this movement in an assembly, where it would trigger a knob and consequently would tighten the object. You can show how you created it?
Message 9 of 19
JDMather
You left all of these details out of your problem description.
Can you Attach your assembly here?
If the assembly is proprietary - then simply Attach a dummy assembly that exhibits the same behavior of your proprietary data.
Also, include an additional relevant information (videos/links to similar mechanisms) that will enhance the efficiency of time spend developing a solution for your Design Intent.
Message 10 of 19
creocatia3d
Sorry, it's still a project, but what I'd like would be like this tweezers
https://www.youtube.com/watch?v=EXIN9nGgFZo
... let's imagine trying to get this part out of the clamp,
when forcing the pincer with the piece, it would tend to abir but returned in position.
I tried with contact set, but the clamp does not return to normal nor open.
Is this only with dynamic simulation (animation) or with a component assembly?
Message 11 of 19
j.palmeL29YX
This is a completely different situation than the one shown in the first picture.
Before we waste any more time on this issue, please describe what you really need, what you want to do, what you expect and what you need it for?
Simple deformations of an part can - in certain circumstances - be realized with adaptive parts. But - I say it again - we must exactly know what you want. You have to tell us more detailed.
cadder
Jürgen Palme
Message 12 of 19
kelly.young
Autodesk Support
Autodesk Support
Hello @creocatia3d indeed your design intent is not very clear. Can you supply an image or a sample of what you are trying to achieve?
From your explanations I'm envisioning something like an X-Acto knife holder?
What are you trying to get Inventor to do? Have an adaptive Collet that will compress as the Collar is tightened?
Something like this?
DYNAMIC SIMULATION - IS THIS POSSIBLE IN INVENTOR PRO??
Please select the Accept Solution button if a post solves your issue or answers your question.
Message 13 of 19
creocatia3d
Perfect!!
I just want to know if I can simulate this manually.
In the study environment, it was excellent. Perfect.
In this same example of yours, you would drag the piece with the mouse and it would deform to enter.
I thought about using contact set and flexible but without success.
Message 14 of 19
j.palmeL29YX
@creocatia3d wrote:
Perfect!!
Attach your assembly here. If the assembly is proprietary - then simply attach a dummy assembly that...
That's the wrong way to get it (perhaps) to work.
Don't you read our answers, do you? And why you don't answer to our questions?
cadder
Jürgen Palme
Message 15 of 19
j.palmeL29YX
Attached 3 examples how you can simulate / animate a deformation of a part in the iam-envioronment.
To see an animation do this:
- in the browser open the folder Relationships
- Right click the DRIVE_ME constraint
- Choose Drive and start the animation.
Although the examples were created with a German Inventor, the working principle should be recognizable.
If you understand the princip you should be able to decide if your project can be realized.
To animate a deformation of a part by dragging with the mouse I don't know a solution.
HTH
cadder
Jürgen Palme
Message 16 of 19
j.palmeL29YX
... and a sample similar to your first picture.
cadder
Jürgen Palme
Message 17 of 19
kelly.young
Autodesk Support
Autodesk Support
@creocatia3d no, dragging the part won't deform on screen using Contact Set, you have to Drive Parameters. It would work for a static tweezer with a single hinge point, but having it bend by dragging the mouse is a limitation.
Is there a reason you need to do this by dragging instead of running by known conditions?
The more information supplied about your design intent as a whole would be helpful in finding the best way to make this contraption your are envisioning.
Message 18 of 19
jmartcarvalho
Hi...!
Simulations shown are very interesting, however I would like to see/know/understand all the steps behind the animation of the tube...!
Thanks for the attention given.
Sincerely:
João Carvalho.
Message 19 of 19
j.palmeL29YX
Above are shown a lot of animations which show different techniques/methods to animate a deformation. Which of them do you mean?
And did you try to analyze the attached ipt's / iam's? Did you see the video posted by @kelly.young? What do you don't understand, at which point do you need supporting assistance?
Jürgen Palme
