Inventor 2018: Converting Mesh with Mesh Enabler to Solid Issue
I've been trying to work with meshes recently.
I would use the AutoCAD format but I cannot find any.
Right now, I'm using Mesh Enabler for Inventor, which should convert a mesh into a solid, but it is converting to something else (See attached screenshot).
I am trying to turn it into a solid so I can customize it by adding some holes, but I cannot do so because it isn't solid.
The original file is: https://www.thingiverse.com/thing:31056/files
Any help would be appreciated
@Anonymous,
marius.gildehaus has edited your subject line and embedded pictures for clarity
Original: Mesh to Solid Conversion Problem
basically, mesh enabler isnt working the way i indented it to, and i don't know how to fix it.
johnsonshiue
Hi! Mesh Enabler converts mesh to composite surface body. You will need to use Stitch command to turn it into a solid, assuming the mesh is water-tight.
Many thanks!
Software Test Engineer
WHolzwarth
This needs some work, but end result is not bad.
2018 IPT and STEP in ZIP.
STEP contains cleaned Inventor data
Walter Holzwarth
marius.gildehaus
Great job as always @WHolzwarth Smiley Happy
Hello @Anonymous!
Does the data from @WHolzwarth help you with your issue?
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Thanks!
Marius Gildehaus
Product Manager Sheet Metal
