Inventor frame generator not updating with sketch changes
B-rad1011
B-rad1011
Ever since upgrading to Inventor 2023, there have been a lot of instances where when changing a sketch that is driving frame generated parts, the parts will not snap back to the lines they were created from. Rebuild All does not do anything. The only thing that appears to work is deleting the old members and replacing them with new. This seems to happen with models that were created before 2023 and copy designed via Vault. Are there any other ways to fix this or is this a bug that needs to be looked into? Any help is appreciated!
kacper.suchomski
Hi
Be sure to edit the reference part file you insert into the assembly at the beginning, not Skeleton123.
Another question is the share of potential manual machining of components in the meantime.
Kacper Suchomski
Can you post the dataset?
I'm unable to replicate on 2023.3
B-rad1011
Well I was taking things out to simplify the model to just the frame and that appeared to have fixed it... I had a subassembly of parts in the same model and once I deleted that, the frame popped back into place. Not sure why that was causing an issue though as they were not related in any way.
