iProperty Function That Displays String Depending On Boolean
cstarker6VCG4
cstarker6VCG4
We use iLogic functions to populate the Title iProperty in this general fashion: TYPE: PARAMETER 1, PARAMETER 2, FEATURE 1, FEATURE 2, etc. All of these reference custom iProperties. The "FEATURE" strings should appear in the Title only if the corresponding iProperty is Yes (the design has the feature).
What code do I enter into the Title text field to display a string if an iProperty is Yes?
Frederick_Law
Shouldn't when there is no FEATURE, FEATURE 1 and FEATURE 2 will be empty?
I did similar and leave the iProperty empty.
Add them all to text field: <First> <Second> <Third>.
I think there is iff() statement.
cstarker6VCG4
How do I use an if statement here in the Title field?:
johnsonshiue
Hi! I don't think this can be easily done using Property expressions. An iLogic rule can help.
Many thanks!
Software Test Engineer
