Hey Smart Inventor Folks,
I have a little snag in a file I am working on. I have created a multi value parameter "Top_Punch" and loaded it into a form. Worked great.
I then created a second multi value parameter "Top_Punch_2" which contains the same multi value info as the first parameter.
The Ilogic form I have used shows the drop down for "Top_Punch" parameter, however the parameter of "Top_Punch_2" is showing a single (read only) value from the parameter - no drop down option ... Does anyone know why is is happening?
Also to note the icon on the form is different for the 2 parameters.
Cliff
Solved by JaneFan. Go to Solution.
Hi Cliff,
It seems you dragged "Top_Punch_2" from iProperties tab instead of parameters tab, so that you are seeing the issue.
In iProperties, "Top_Punch_2" is not multi-value.
To get multi-value combo-box of "Top_Punch_2", please find and drag it from Parameters tab. Please change the filter condition via the upper command if the parameter doesn't list there.
