Inventor Forum
Inventor form not displaying dropdown multivalue parameter list
2 REPLIES 2
cliff.kelly
463 Views, 2 Replies
Hey Smart Inventor Folks,
I have a little snag in a file I am working on. I have created a multi value parameter "Top_Punch" and loaded it into a form. Worked great.
I then created a second multi value parameter "Top_Punch_2" which contains the same multi value info as the first parameter.
The Ilogic form I have used shows the drop down for "Top_Punch" parameter, however the parameter of "Top_Punch_2" is showing a single (read only) value from the parameter - no drop down option ... Does anyone know why is is happening?
Also to note the icon on the form is different for the 2 parameters.
Cliff
2 REPLIES 2
JaneFan
in reply to: cliff.kelly
Hi Cliff,
It seems you dragged "Top_Punch_2" from iProperties tab instead of parameters tab, so that you are seeing the issue.
In iProperties, "Top_Punch_2" is not multi-value.
To get multi-value combo-box of "Top_Punch_2", please find and drag it from Parameters tab. Please change the filter condition via the upper command if the parameter doesn't list there.
Jane Fan
Inventor QA Engineer
cliff.kelly
in reply to: JaneFan
Ah! such a simple mistake. Thank you very much for finding this.
