Inventor files on ipad
Milan_Nosil
Milan_Nosil
Hi everyone.
I have a question about opening files from Autodesk Inventor in ipad - it is possible now?
All forum strings are old. Has anything changed? If I have data on a network drive, can I view it from my iPod?
I don't want to use Vault Mobile because we don't have a Vault Professional.
Thanks for any advice.
Milan
SharkDesign
Easiest way is to send them to Fusion first and use the fusion app.
You can't edit them on iPad if that is what you want to do.
  Inventor Certified Professional
Gabriel_Watson
Sending it to the cloud to view through https://viewer.autodesk.com is another choice if all you need is just measuring or using it as a reference to manufacture/present it/etc.
Milan_Nosil
I have data on a network server and I would like to open it. I don't want to send or edit them. I don't think it's possible with ios ...
But thak you for your advice.
Milan
SharkDesign
Do you use Vault? There's a thin client for that you can run on iOS.
There's no way to directly access your network drive for a viewer.
If it's specific files you can use the shared view. Not tried it on iOS but it's web based.
Milan_Nosil
Thank you for your ideas 🙂
Milan
