Inventor exports PDF's with errors
basautomationservices
I have a problem where sometimes PDF's I export from inventor are not exported correctly. I get an error when opening it in acrobat/edge.
It doesn't happen consistently on drawings. Sometimes one time I will get an error then I export it again and it's fine.
Anyone has had the same problem / knows how to fix it?
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
DavidWarta
In the past we have had a similar problem. The culprit was an embedded image on the drawing which was invisible. A temp workaround was not using the export function but the print to pdf.
D.Warta
Van Halteren Technologies Boxtel B.V., Netherlands
R_Cygan
When Exporting IDW to PDF,  (While accidently I have the previous PDF open), got an error- Ok, can not override.- I accept
but when next time exporting (even no PDF is open) getting error , every single time!!! - always! a bit annoying, Can be that fixed?
Please help -, any fixed Rule or?
Many Thanks
johnsonshiue
Hi! Are these two fonts available on your machine? Please share the idw/dwg file here. The forum experts can help take a closer look.
Many thanks!
Software Test Engineer
