Show only
Search instead for
I just reinstalled Inventor and after I go to work in my old project I've noticed that the usual save, save and run, cancel has been replaced by ok, cancel.
Are there settings for this somewhere? I can't find them.
Hi! Is this iLogic rule editor or VBA editor? If it was iLogic rule editor, the buttons look wrong. Please make sure .Net 4.7 is installed and all critical Windows updates are installed. If it still behaves this way, please use Inventor Reset Utility (All Programs -> Autodesk -> Inventor 2019 -> Tools) to reset options back to install default.
Many thanks!
Johnson Shiue (johnson.shiue@autodesk.com) Software Test Engineer
