Inventor Drawing View Overlapping causing color to disappear
KaynePellegrino
Message 1 of 9
KaynePellegrino
 For some reason, when in the drawing in Inventor (Image Attached [ Inventor drawing - In Inventor]), the overlapping views look fine and the views are shaded how they should. But once I print it to PDF or straight to a printer, the areas of the views that overlap cause the lower level views to lose color (Image Attached [Inventor Drawing - Printed to PDF]).
    I'm not sure if this is a bug, or a setting issue. But it's been like this for a few weeks and I'm not sure what to do.
Replies (8)
Message 2 of 9
bradeneuropeArthur
This may be caused by the "Deferupdate" of the drawing.
Is this the case for you?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
KaynePellegrino
I am not sure what the 'Deferupdate' is
Message 4 of 9
nautinox
Observer
Observer
I have the same problem.
It's clearly a bug (I've been working with Inventor for 20 years and this problem has never occurred).
I haven't found any way around it.
Message 5 of 9
johnsonshiue
Hi! This is a known bug (INVGEN-81003). It has been fixed in our internal build. We are in the process of integrating the fix to the coming 2025.3 update.
Many thanks!
Software Test Engineer
Message 6 of 9
Raksmey.wat4SUTC
You can avoid this for now by saving the print to PDF and print it from there.
Message 7 of 9
KaynePellegrino
It still does it even when I print to PDF
Message 8 of 9
Raksmey.wat4SUTC
Not the right way, you have to export to pdf. not microsoft print pdf.
Here what I did, I go to file> export>PDF
then save it to my desk top. and it works, no discoloration.
Let me know if this work for you.
Message 9 of 9
Raksmey.wat4SUTC
then save it to my desktop. and it works, no discoloration.
