Inventor Drawing Balloon With Text Attached
acramerWSZRE
acramerWSZRE
I am try to create a balloon style to have the item number in a balloon with text after it. I need it to look like the top one (which is just text next to the balloon) but it wont retain the balloon as it looks like in the bottom one.
kelly.young has edited your subject line for clarity:  Balloon editing
kelly.young
Autodesk Support
Autodesk Support
Hello @acramerWSZRE I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
If you create a Leader Text attached to the balloon without creating the Leader Line, it will stick to it.
RMB and select Continue without creating the leader line.
This will bring up the Format Text box and you can link to your parameters. It will follow wherever you move it and the input can be controlled fairly easily.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
acramerWSZRE
Thank you for the help.
