What does gravity do?
elofusion
528 Görüntüleme
2 Yanıt
Mesaj 1 / 3
elofusion
I want to know what gravity does? If I select mild steel for my model does gravity calculate it's own weight?
0 Beğeni
Kabul edilen çözümler (2)
529 Görüntüleme
2 Yanıt
Mesaj 2 / 3
jhackney1972
Kabul edilen çözüm
Gravity, it keeps us all from floating into space!  You did not mention what environment you are asking about.  I can only assume you are referring to the stress analysis or simulation environment since gravity settings do not appear in part or assembly environment.  In these environments it adds the effects of gravity on your analysis.  The density of materials determine the weight of an object in the part and assembly.
You need to define your question a little more.
John Hackney, Retired
0 Beğeni
Mesaj 3 / 3
kelly.young
Autodesk Support
Autodesk Support
Kabul edilen çözüm
Hello @elofusion if you can supply a bit more information that would be helpful. Here are a couple of links that might help you out:
Tutorial: How to simulate falling things in Autodesk Inventor
Gravity
To Define Gravity and Other External Forces for a Simulation
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
0 Beğeni
