Inventor custom standards.xml and objectdefaults.xml not being read correctly
mitchELAHB
mitchELAHB
Hi all,
I'm having trouble with inventor, vault and a custom drawing style. everything we had was working fine on 2022 until we upgraded to 2024 the other day. I migrated vault server, then vault client then inventor over to the new versions, did the all the design data and standards changes needed, checked them back into vault and did a delete and get on all the other computers design data folder (which is how we did it before) and now every other computer except one is getting this error when they open a file for the first time. I have tried many things including doing the process all over again on a different computer and having the same problem.
Gabriel_Watson
Just to test, have you tried removing read-only on your local workspace copies gotten from Vault?
Also, you should post this (or moderators will move) to the Vault forum.
johnsonshiue
Hi! Please note that the styles library needs to be migrated before it can be used in 2024. Please check out the styles and use Styles Library Manager to migrate the styles to 2024.
Many thanks!
Software Test Engineer
