How to modify dimension style?
cjfgns1003
cjfgns1003
Dimension and leader text entered in Inventor IDW converts to blurry text when converted to DWG.
Trouble with text settings?
*Please check the attached file.
kacper.suchomski
Expand the annotations panel, then expand the list of styles and select manage styles.
Kacper Suchomski
johnsonshiue
Hi! This could be a corrupted style issue or something was not set correctly. Try a simple test to see if it behaves differently. Save the idw file as Inventor dwg. Open the dwg file in AutoCAD -> EXPORTLAYOUT. Does the dimension text look nicer? If yes, it might be an Inventor bug. If no, it might be an AutoCAD conversion issue.
Many thanks!
Software Test Engineer
