Inventor Assembly Keep Color When Converting to Step File
Message 1 of 21
Hi all
Please can someone help me how do i keep colours saved on iam assemble after when moving it into a Step file.
I have highlighted some componets/parts which i have been working on which is perfect on iam file. But when i save it on Step file l loose the highlight colouring.
Thank you for your help.
kelly.young has edited your subject line for clarity: Colour
Replies (20)
Message 2 of 21
mcgyvr
Of the 2 STEP format options I believe you need to use AP214  VS 203 to retain color information..
Message 3 of 21
mcgyvr  iam using inventor 2015 and on the step file saving option i cant see AP214 VS 203. Do i need to download it as at extra software option/
Message 4 of 21
Matheuspool
Firstly to begin these steps you should change the part in the ipt environment, even if it is in assembly ... come on:
Message 5 of 21
mcgyvr
You should have it.. I thought thats been around since 2014 and earlier..
Here is the help for Inventor 2014 that shows the ability to select the desired format..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Inventor/files/GUID-4D82489E-F40D-4EB3-89E5-F91E6229B1FD-htm.html
Message 6 of 21
Thanks pal but its not the case i have been doing the very same way you just said but once i move the part into step file the new added colour doesnt show
Message 7 of 21
thanks but it doesnt work at all.
Message 8 of 21
JDMather
Can you attach Inventor file here that exhibits this behavior?
Message 9 of 21
johnsonshiue
Hi! I am sorry I am confused. This should work. I have tried in on all releases I have. The color is retained on import. Please attach an example here. Or, record a Screencast showing the exact workflow. I am missing something here.
Many thanks!
Software Test Engineer
Message 10 of 21
Thank you very much for your responce, if does work wit parts l make myself but it's refusing with the past l import from my company website. Unfortunate l am at home now but l will  upload the drawings tomorrow when l get to  work.
Message 11 of 21
I will thanks very much tomorrow morning.
Message 12 of 21
johnsonshiue
Hi! Then I guess the color was not in the exported STEP file. Could you attach the STEP file here tomorrow? Also do you know what CAD system generated the STEP file?
Many thanks!
Message 13 of 21
good morning  i have attached the 2 drawings.
Message 14 of 21
Hi
i have attached the 2 files Mod practise has colour and Mod  practise 2 does not have colour and is the step file version.
Message 15 of 21
mcgyvr
@Anonymous wrote:
Hi
image files are not helpful..
Please attach the step file that is not coming in with the colors properly assigned and let us know what color you expect it to show once imported..
Message 16 of 21
my first normal assembly with colourmy first normal assembly with colourStep file without colour. I am trying to save the step file in a way that it would return the colours for example the blue shown on the first  diagramStep file without colour. I am trying to save the step file in a way that it would return the colours for example the blue shown on the first diagram
Message 17 of 21
can you have a look at my diagrams which l have just uploaded about my problem.
Message 18 of 21
can you have a look at my diagrams which l have just uploaded about my problem.this is my original assemblythis is my original assemblymy step file versionmy step file version
Message 19 of 21
Curtis_Waguespack
Hi @Anonymous,
In the *.ipt files, expand the browser and find the Solid Bodies folder. In the Solid bodies folder select the body or bodies and choose Properties from the right click menu. In the resulting dialog choose Strip Color Overrides ( or something similar).
I am going from memory on the steps described above, but removing the color overrides is likely the action that you need to take to get the results you're after. I'll try to check back later this morning when I'm looking at Inventor, to ensure I've not miss-remembered the steps.
I hope this helps.
Curtis
Message 20 of 21
Hi  Curtis
Thank you very much for help but my step files also comes with iam not with itp. This makes it impossible to view the solid part option.
see attached diagram.
Step file comes as iam not itpStep file comes as iam not itp
