Inventor Assembly Constraints On Wheel Gear Ratchet Pinion
gert-jan.van-dam
Message 1 of 11
gert-jan.van-dam
I've made a exercise and want to complete it with a working assembly.
If I turn the wheel I want the gear to turn but can't find a sollution how to do this.
See for the drawings and a little film the attachments.
Can someone here give me a solution how I can make it work?.
kelly.young has embedded your image and edited your subject line for clarity: Making constrains in a assembly with a exercise.
Replies (10)
Message 2 of 11
Xun.Zhang
Welcome to Inventor community!
I believe contact solver can help you out, for more detail, you can refer to -
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-FA1A8282-3A7E-45BE-8DB3-F637FB1C3292
Make sure, you have set the component as contact set before simulate the contact solver.
Hope it helps!
Xun
Message 3 of 11
TheCADWhisperer
An assembly must include parts. ( *.ipt files)
Message 4 of 11
kelly.young
Autodesk Support
Autodesk Support
Hello @gert-jan.van-dam I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Thanks for attempting to attach the assembly, but all parts need to be included. Can you try using Pack & Go as .zip to share your parts?
Are you trying to do Dynamic Simulation, visual representation for Fitment, or rendering within Inventor Studio?
There have been a few conversations with good attached examples to inspect:
springs - ratchet and pawl?
Ratchet and Pawl Mechanism
Couldn't find an explicit ratchet video demonstration, so if you can attach your parts and describe what you're wanting to accomplish that would be helpful for forum experts.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 5 of 11
gert-jan.van-dam
Dear Kelly, i'm trying to do Dynamic Simulation and practice to work with constrains 🙂
I hope the attachment contains the correct files you asked for.
Message 6 of 11
WHolzwarth
I've tried with DS (2018 files)
But I don't think it would be working well in real life, either.
Comments welcome.
Walter Holzwarth
Message 7 of 11
kelly.young
Autodesk Support
Autodesk Support
@gert-jan.van-dam thanks for the good setup @WHolzwarth. I simplified it further by turning off the chamfer on the side of the gear tooth, seemed to help simplify the selection, but don't think that's an issue.
No matter how I set it up the 2D Contact seems to get stuck in the bottom.
I can get it to push around making each part a Contact Set and then using Transitional Constraint but is seems to lock up leading me to believe the design might be slightly off.
Haven't used this setup very often so might be missing something. Possibly loosen the tolerances and see if that works better.
Message 8 of 11
TheCADWhisperer
Do you intend for the pawl to only swing by gravity - or can a Spring Force be added?
The ratchet is not doing any work - so at a minimum Friction will need to be introduced into the Revolution Joint.
Message 9 of 11
gert-jan.van-dam
thx for youre help so far, I will keep on trying to make it work.
Message 10 of 11
gert-jan.van-dam
I've tryed to set gravity in the ratchet, but don't think it worked (sorry beginner  Smiley Frustrated ), perhaps I can add a spring to make it work.
Message 11 of 11
kelly.young
Autodesk Support
Autodesk Support
@gert-jan.van-dam were you able to further the setup using a spring?
