inventor application error
 How to resolve inventor program errors can not be opened?
mcgyvr
@Anonymous  Can you translate that dialog box error to English for us please?
johnsonshiue
Hi! Based on my quick search, it seems to be related to incorrect or incomplet install of Microsoft C++ Redistributable.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Please go to Control Panel and look for the most recent Microsfot C++ Redistributables installed around the same time as you installed Inventor. Uninstall those. Then run Repair Install (right-click on the Inventor in Control Panel -> Uninstall -> Repair Install).
Many thanks!
Software Test Engineer
inventor.exe   application error
The application failed to start properly(0xc000007b). Please click OK to close the application
Johnson, thank you very much for your answer
