Create loft
Create loft
davorxxx
Create loft
davorxxx
How do I get an elbow made correctly. Three are different elbow when I make a loft I don't like any of them. I would like it to be on the line as in sketch 1 and sketch 3.
-niels-
Can you use those sketches as guiderails for you loft?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thomas_Savage
Hello @davorxxx
Can you attach part 21,22,23 please.
As with just the assembly they are unresolved, so can't see the part to solve the issue.
Thomas Savage
Design Engineer
bhavik4244
@davorxxx
you have missed attaching the part! However, with a snap, I merely got your concern and made the concept that could help you.
I have attached a part here that might solve your issue and give you the right way to model it out.
Bhavik Suthar
davorxxx
I can't open your ipt.file, just the image, and in the image I see that the dimensions have changed. I need the dimensions exactly as I specified them.
bhavik4244
@davorxxx
Here you go 🙂
Bhavik Suthar
johnsonshiue
Hi! I suspect you could use Guide Rail Sweep. Basically, use the center rail as the Sweep Rail and use the outer rail as the Guide Rail. It should give you the precise geometry.
Many thanks!
Software Test Engineer
