SUB ASSEMBLIES IN PART LIST
baliasM74U3
baliasM74U3
Hi Experts
INV 2018
How can i show the parts within a sub assembly in the part list of the main assembly ?
In the image attached, I need to show the parts under sub assembly 3, 5 and 6 in the part list of the main assembly.
Basil
Thomas_Savage
Hello @baliasM74U3
In your BOM in the assembly, on structured tab, right click on structure and select view properties.
Then select all levels from the drop down.
Then edit your parts list in your drawing, and you will see a + sign. Expand this and then your sub assembly will show in your parts list when you expand the + sign.
Hope this helps.
Thomas Savage
Design Engineer
johnsonshiue
Hi! Thomas is right. Simply expand the level to All Levels. Another option is to make the subassemblies Phantom so the components within subassemblies will be "promoted to the top-level.
Many thanks!
Software Test Engineer
