Inventor .3ds export
gregor.leban
Message 1 of 12
gregor.leban
can you help me.
Is there a way to export from inventor into .3DS format.
I need it to import objects info Relux, to add lights.
Thanks!
Replies (11)
Message 2 of 12
CCarreiras
Hi!
3DS can open inventor files directly.
CCarreiras
Message 3 of 12
gregor.leban
Yes, but I need:
Inventor -> .3ds export -> import to Relux
Message 4 of 12
CCarreiras
If you have 3DS, open Inventor files in 3DS and save as.
If you dan't have 3DS, In inventor you can save as OBJ file. Check if Relux can open these king of files.
CCarreiras
Message 5 of 12
gregor.leban
I dont have 3ds. I have my inventor project.
Relux cant import .OBJ only:
Message 6 of 12
CCarreiras
Well... try the DXF.
If you have Autocad.
Export Inventor file as DWG Autocad.
In Autocad, export DWG as DXF.
CCarreiras
Message 7 of 12
gregor.leban
I want 3D, not 2D import.
Message 8 of 12
johnsonshiue
Hi! Another option is to export Inventor files as fbx files. Relux CAD might be able to import fbx files.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=6868205875192483688&appLang=en&os=Win64
Many thanks!
Software Test Engineer
Message 9 of 12
chris
@gregor.leban How many parts are you talking about? I have Moi (Moment of Inspiration), you can export from IV as .step then open the .step in Moi and then export as .3dm.
If you don't have too many parts I can convert them for you.
Message 10 of 12
chris
@gregor.leban Here are my export options from Moi.
Message 11 of 12
gregor.leban
well I need a solution not only for today but for the future too.
I have the whole building in inventor, so yes, there are some parts...
Message 12 of 12
chris
well check out Moi, I believe there is a 45 day trial (full tool set) and then it's only about $400, if you get it I can show you the work flow, (very simple)... I only use the software for poly conversion and export
