Offset command
Offset command
NigelHay
Advisor Advisor
Offset command
NigelHay
I've noticed a change in the offset command recently. Previously, when using loop offset I could project say the outer profile of a part, start offset, then drag the projected line in & enter a dimension. That would usually fully constrain the offset at the desired dimension from the projected lines.
Now I do the same but the offset lines are not constrained , there is no dimension between the projected & offset lines, I can just drag them around.
Is this a deliberate change or have I inadvertently changed a setting somewhere? I can't see any setting if I choose 'offset' & then R.Click.
JDMather
Can you Attach file here that exhibits this behavior?
You should see options when right click.
SBix26
I think you accidentally changed a setting.  As @JDMather advised: look in the right click menu:
Sam B
Inventor Pro 2023.2 | Windows 10 Home 21H2
NigelHay
That's the one, the 'constrain offset' was unticked. It works OK now, thanks to both of you.
