Inventor 2027 Slow?
Inventor 2027 Slow?
mingyargd
Message 1 of 13
Inventor 2027 Slow?
mingyargd
Is it just me or Inventor 2027 is very slow? seems to be very laggy?
This are my specs:
AMD Ryzen Threadripper PRO 7975WX 32-Cores (4.00 GHz)
128Gb RAM
Nvidia RTX4000 ( latest drivers )
Windows 11 Pro
Replies (12)
Message 2 of 13
Paul-Mason
Pleased I'm not the only one that's noticed I've noticed and said the so in this post,
https://forums.autodesk.com/t5/inventor-forum/inventor-2027-assembly-and-drawing-file-update-time/m-...
Inventor 2027 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
Message 3 of 13
mingyargd
For me even opening and closing simple parts its a struggle, I regret updating from 2026
Message 4 of 13
lauri_barnhart
Hello @mingyargd, thanks for posting in the community!
I wanted to follow up to see if you're still facing this problem?
If you were able to fix the issue, please share what worked for you.
If the issue persists, let us know with an update so we can assist further.
Thanks!
Lauri | Community Manager
Message 5 of 13
Paul-Mason
Yes I am, both I and the AI have run out of ideas on how to fix it
hears my Machine specs
Edition Windows 11 Pro
Version 25H2
Installed on ‎04/‎03/‎2026
OS build 26200.8328
Experience Windows Feature Experience Pack 1000.26100.304.0
Device name redacted
Processor Intel(R) Core(TM) i9-9920X CPU @ 3.50GHz (3.50 GHz)
Installed RAM 128 GB (128 GB usable)
Graphics card NVIDIA Quadro P4000 (8 GB)
Storage 1.36 TB of 5.46 TB used (spred over three drives C,D and E)
Device ID 82C030FA-D392-4082-88C3-13CDE36CE7B9
Product ID 00330-52268-94798-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
I've got 2 x 2TB SSDs one for programs the other for data & files both have the same performance specs, D is a backup of my data & files and is a standard HD
As I said this has only manifested in 2027.
Inventor 2027 Pro
Xeon
Message 6 of 13
mingyargd
Hello, no, the problem persist, it’s painful, every action is lagging like 5 seconds, open files, commands, creating new parts, drawings, everything
I wish I could go back to 2026
Message 7 of 13
Paul-Mason
I've also opening a part from within an upper level assembly also takes an age
Inventor 2027 Pro
Xeon
Message 8 of 13
BDCollett
This does not seem to be a consistent issue with all users. My 2027 on a very average laptop does not have these problems with opening and creating new files.
That makes it hard to see what the root cause is.
Message 9 of 13
Paul-Mason
One thing in common my problem is that ALL the IPT. IAM and IDW were original created on and then migrated from 2026 to 2027 after being copied to a NEW folder.
Inventor 2027 Pro
Xeon
Message 10 of 13
johnsonshiue
Hi! The behaviors do not sound right to me. Please make sure all the critical Windows updates, the latest graphics driver, and all the critical PC vendor updates (including BIOS) are installed. Use Windows Disk Cleanup to remove cached files. You may want to record a Performance Feedback report and share the report ID with me at [email protected]. Or you may use Microsoft Process Monitor to record the 5 seconds detail and share it with me.
Many thanks!
Software Test Engineer
Message 11 of 13
navya_gelli
Hi @mingyargd ,
I wanted to check in and see if  johnsonshiue response helped resolve the issue or  you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
Navya | Community Manager
Message 12 of 13
mingyargd
Sorry for the late reply, I was on holidays, I was so frustrated on how the system was performing that I did a full clean OS installation and installed the new version of the 2027 software, now Its working fine, I dont know what fix it, the new install or the software update
Message 13 of 13
hkilic896XF
Inventor is not slow, we'r living fast.. 😁
Waiting for hours to update an idw's sheets.. 2026.3
Yes, Inventor is good.
My grandma & fa are also good.. 😂
