Inventor 2026 Tube and Pipe - schedule of Elbows problem
FrancPro
Message 1 of 17
FrancPro
I create Tube and Pipe assemblies and I select Schedule 40 for my Pipe Run.
The pipe that's created is Schedule 40 but the Elbow is NOT.
It gives me an elbow with a very very thin wall and I cannot fix this.
Replies (16)
Message 2 of 17
johnsonshiue
Hi! Is it possible to share the Inventor files (iam, ipt, and idw/dwg) in zip here? I would like to understand the Drawing behavior better.
Many thanks!
Software Test Engineer
Message 3 of 17
FrancPro
Thanks for your help. Zip file attached.
Message 4 of 17
johnsonshiue
Hi! Many thanks for sharing the files! But not all files (Content Center parts) are included. Please use Pack&Go to get all the files, zip up, and share it here.
Thanks again!
Message 5 of 17
FrancPro
Attached
Message 6 of 17
FrancPro
I have recently installed Inventor 2026 and the piping example I've attached is using the "Default" project profile, not a project we've modified for our company.
It's just using the standard "ASTM A 53/A-ASME B16.9 - Steel Butt Welded Pipe" settings without any modifications.
It's a straight pipe, then an 90° elbow and then another pipe.
Message 7 of 17
gcooper79
Hi FrancPro
When you set up you piping style, did you select the elbow family or the sch.40 elbow from below the family?  My guess would be that you selected the family.  Sometimes when you do this, Inventor will place the first record of the family in your route (this would likely be Sch.5s).  Try selecting the sch. 40 instead and see if that resolves your issue.
Family is red, record is blue.
Edited to add screenshot
Graeme
Message 8 of 17
FrancPro
But if I select that it is a Schedule 40 pipe run, shouldn't it automatically know that the elbows are to be SCH40 also?
Message 9 of 17
gcooper79
You would think so.  I'm not sure why it doesn't follow the schedule from the main style window.
Graeme
Message 10 of 17
johnsonshiue
Hi! I took a quick look at the assembly in ELB.zip. The elbow part has a very thin wall thickness (T = 0.083"). Maybe there is a wrong set of values stored in the Content Center library. I will work with the project team to understand it better.
Many thanks!
Message 11 of 17
Yijiang.Cai
@FrancPro @gcooper79 @johnsonshiue We could go to the T&P run environment, and right-click the "ASME B16.9 Short Radius 90 Deg Elbow 6 x 0.083:1" to change size. I suppose you prefer to pick the thickness of elbow to match the thickness of pipe. You could pick the right member from family view, and it will work fine.
BTW, the first member of elbow with the diameter &  schedule matching with pipe will be used here, and user could use context menu command "Change Size" to pick the expected one later. Thanks!
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: [email protected]
Message 12 of 17
FrancPro
Why do we have to do anything?
I chose SCH40 pipe run, and I shouldn't need to do anything else.
Message 13 of 17
Yijiang.Cai
@FrancPro do you prefer to keep the same thickness between pipe and fitting here when creating the pipe run? Is that your idea? Thank you!
River Cai
Autodesk, Inc.
Message 14 of 17
FrancPro
Of course, that is what normally happens in the piping industry.
The pipe thickness and the elbow thickness MUST be the same.
Message 15 of 17
FrancPro
If I select "Schedule 40", then all pipe items should be the thickness specified by the "Schedule 40" standard.
This includes all pipes, all elbow, all reducers, etc.
This is crucial, that is why we have strict engineering standards.
Message 16 of 17
gcooper79
What is the point of selecting the piping schedule from this dropdown when you then also need to select the elbow instance from the family dropdown in the library browser too?
Graeme
Message 17 of 17
Yijiang.Cai
Many thanks for the more details, and it has been tracked as [INVGEN-85384] for investigation.
Will keep you updated!
River Cai
Autodesk, Inc.
