Vault tab not showing in Inventor
tmalage
tmalage
After installing new Autodesk inventor 2025, I don't see vault tab in inventor before it used show in 2022 but now it not showing for me but for my colleague it shows. I don't know what's issue. see below image.
For me
(No vault option)
For colleague
karthur1
1. Do you have Vault project selected?
2. Under Tools > add-ins, do you see the Vault add-in loaded?
Kirk
tmalage
yes, I see those options (Loaded too) but still I don't see vault tab.
Thanks!
karthur1
Under Tools >add-ins, it says "Automatic/ Loaded"?  If that's the case, you should see a Vault tab.  If not, then:
1. Restart computer (which you probably have done).
2. Start Inventor by right-clicking and "Run as Admin".
3. Try the Inventor reset utility.  But you will loose all Inventor customization that you have done.
Kirk
andrewiv
One other add-in to check.  If you right click in the list of add-ins and then click show hidden members an add-in for EDM should appear.  Make sure that is also Automatic/Loaded.  I had this same problem a few years ago and that is what fixed it for me.
Andrew In’t Veld
Designer / CAD Administrator
