Inventor 2025.1 is now available
ChrisMitchell01
Community Manager Community Manager
Message 1 of 22
ChrisMitchell01
Hello Everyone,
Inventor 2025.1 was officially released today. Please see these resources for further information:
Note: The officially released build number for 2025.1 is 241, (available from Inventor, Help, About). Due to an internal  release issue, build 226 was temporarily available for download from Autodesk Account or Access. If you have build 226 installed it is recommended to uninstall that and then reinstall the official build 241.
Use the following to uninstall build 226:
  1. Type cmd in the windows search box.
  2. Right click and use Run as administrator
  3. Use this command to uninstall:
    "C:\Program Files\Autodesk\AdODIS\V1\Installer.exe" -i uninstall --trigger_point system -m C:\ProgramData\Autodesk\ODIS\metadata\{AA3A19EC-A8EB-37B9-AAED-911E60BDB1F7}\bundleManifest.xml -x C:\ProgramData\Autodesk\ODIS\metadata\{AA3A19EC-A8EB-37B9-AAED-911E60BDB1F7}\SetupRes\manifest.xsd
Then download/re-install build 241 from Autodesk Account/Access.
Hopefully you'll like what's new in this update!
Chris, (on behalf of the Inventor team).
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Replies (21)
Message 2 of 22
BDCollett
The property mapping from parts lists now working correctly is a great one.
Message 3 of 22
pallapinco925
Please, fix the Inventor Interoperability 2025.1 link (in account)
Message 4 of 22
ChrisMitchell01
This is currently under investigation - Thanks for reporting it.
-Chris
Chris Mitchell
Autodesk, Inc.
Message 5 of 22
ChrisMitchell01
@pallapinco925 Please retry the download for Inventor interoperability again now after logging out/in from manage.autodesk.com.
It still shows 2025 in the UI but it should download the .1 version (build 241).
Chris
Chris Mitchell
Autodesk, Inc.
Message 6 of 22
h_eger
Hi Chris,
It's done. I have to work with CMD as administrator and not with Power Shell.
good idea but it doesn't work!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 7 of 22
ChrisMitchell01
The uninstall command needs to be run in the normal windows/DOS cmd window as opposed to in Powershell.
Note that this command only uninstall the 2025.1 update; it should leave the core Inventor 2025.0.x installed so that you can then reinstall the official 2025.1 update.
Chris
Chris Mitchell
Autodesk, Inc.
Message 8 of 22
HideoYamada
Running the command at CMD.exe works for me.
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 10 of 22
niki
Still problems with the Style Library Manager 2025 after this update. Tried full uninstall and a new install download and re-install. Keep coming with this error. Terrible annoying and non of the suggested workarounds would work for me.
Best regards
Niki
Message 11 of 22
h_eger
@niki ,
For me in Inventor 2025.1 Build 241 German, everything works as it should.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 12 of 22
ChrisMitchell01
@niki Have you tried running Styles manager by right click Run as administrator?
Chris Mitchell
Autodesk, Inc.
Message 13 of 22
niki
Yes...   Nothing works
Best regards
Niki
Message 14 of 22
ChrisMitchell01
Have you installed Inventor 2025.1 (build 241) ? This issue was supposed to be fixed in that.
Use Run as Administrator to start Inventor
Then retry the Styles Manager.
Chris
Chris Mitchell
Autodesk, Inc.
Message 15 of 22
niki
I have tried running Inventor.exe as Adminitrator and also the Style Library Manager as Administrator. Nothing works. The Error is still showing up. Tried un-installing and re-intall. No help either.
Running Windows 11 Pro 23H2 (10.0.22631)
Best regards
Niki
Message 16 of 22
BDCollett
Is 2025 the only version of Inventor that you have installed?
Message 17 of 22
ChrisMitchell01
@niki - Did you ever reboot as part of these uninstalls/reinstalls ? It may be possible that a specific dll file didn't get updated if Inventor was still running during the installation process. Could you please search & find a file called RxInventorUtilitiesInterop.dll & check its file properties to see the specific version number ?
Could you please use this info to send us your installation log files? https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-Use-the-Log...
Chris
Chris Mitchell
Autodesk, Inc.
Message 18 of 22
Rory_M
I'm on build 162, release 2025.0.1 dated 05/13/2024.
Should the 2025.1 update be showing in Autodesk Access? It's not there for me.
Obviously I can download and install manually but it would be easier if it did show up.
Message 19 of 22
ChrisMitchell01
Hi Rory,
Yes it should show up there in Access. I haven't heard of others not seeing this update; have you tried exiting/restarting the Access service to see if that helps?
Chris
Chris Mitchell
Autodesk, Inc.
Message 20 of 22
G60Dubs
Built a 2025.1 deployment and post bare install I'm also seeing issues with the 2025 default styles:
https://forums.autodesk.com/t5/inventor-forum/inventor-2025-1-styles-library-issue-bug/td-p/12947202
