Inventor 2024 crash using simplify - substitute
Cami_Fracelli
Cami_Fracelli
Hi all,
I'm getting constant crash when trying to simplify assembly. The creation of the simplified part seems to work well but it systematically crash during the substitute phase.
I'm sure of that because when i try to manually add the .ipt as a substitute : it crashes.
I tried with different assemblies (between 600 and 2000 parts). i've send 14 crash report in the last 24h...
After this post : Inventor 2023 crash using simplify - Autodesk Community from 2022 : i can say :
- my Inventor version is 2024.3.5 64bits
- no visible bad bodies in Ctrl+F7
- windows updated
and
- Half the RAM is still available during this operation.
Did someone experienced something similar ?
johnsonshiue
Hi Cami,
The Simplify workflow crash is usually geometry or file specific. Please share the files with me directly at johnson.shiue@autodesk.com. I would like to understand the issue better.
Many thanks!
Software Test Engineer
