Recently upgraded to 2023.1 then sometimes I can't select object (including components, parts, solid, face, etc.).
Reinstalled 2023, without update to 2023.1. It allows to select like expected. However a major bug was constraints don't work properly. Then I chose to upgrade to 2023.1. At the beginning, no object selection problem. But today, this object selection problem is back again.
It happens in IAM, and IDW. Eg: I cannot select and move a view, nor can I move the view title.
Frustrating....
Solved by johnsonshiue. Go to Solution.
Hi! This is an embarrassing regression on 2023.1. Please either enable Prehighlighting (Tools -> App Options -> Colors) or unload Fusion Interop Add-In (Tools -> Add-Ins). We are working on a fix. It should be available in the coming mini update to 2023.1.
Many thanks!
Hi! Yes, I believe all selection operations are impacted by this defect. Please either turn on Prehighlighting or unload Fusion Interop Add-In. The fix will be available on 2023.1.1 update.
Many thanks!
This Bug still exists in the 2023.1.1 update! Its nearly impossible to select a Grip point in the IDW editor, if I am trying to grab a dimension and adjust I'd say I have to hit some magical spot and it finally grabs the object I am trying to move.
Added a New Screen Cast
Also the workaround you posted does nothing to address this, the problem is still there, was this fix not added to the 2023.1.1 update?
Hi! The particular issue captured in the screencast is a separate one. The selection bug on 2023.1 is in the Part and the Assembly environments, not in the Drawing environment.
I tried a simple case to reproduce the behavior captured in the video. But, I could not seem to reproduce it on 2023.1.1. Check out this option. Open the drawing and go to Tools -> Doc Settings -> Drawing -> Invalid Annotations -> what boxes are checked there?
Many thanks!
Hi! Your settings are the same as mine. I cannot explain the behavior. Another place to check is Tools -> App Options -> General -> Locate Tolerance. Mine is set to 7. What is yours set to?
Many thanks!
