Inventor Forum
Inventor 2022 Nesting - Package name to Header
4 REPLIES 4
JVeenboer
599 Views, 4 Replies
JVeenboer
I did some nesting with Inventor 2022 Nesting and half way through I noticed that the package name does not get pulled through to the header on the nesting pattern, is this a problem or do i have something wrong in my files.
Tags (1)
4 REPLIES 4
AmyLiu
in reply to: JVeenboer
AmyLiu
@JVeenboer
if i understand correctly, you may want to show the information in header of Nesting result in canvas.
if that's the case, then you could do as the image shown, click Options to invoke the command dialog, select header in the left structure, and select what you want to be shown. or you could use Reset in the left bottom of dialog to show all default properties(include packaging).
hope it helps.
Amy Liu (cui.liu@autodesk.com)
Senior Software QA Engineer
@JVeenboer
hope it helps.
JVeenboer
in reply to: AmyLiu
JVeenboer
Hi thank you for the information I have done that but the packing information is till blank.Capture.JPG
AmyLiu
AmyLiu
@JVeenboer
I got your problem, yes, it was an issue, ticket TRUNINV-2318 logged, we'll dig into the problem and fix it.
for a workaround, you could see the packaging information from Report command,
and check the InventorID property:
hope it helps.
@JVeenboer
hope it helps.
JVeenboer
in reply to: AmyLiu
JVeenboer
Hi @AmyLiu thank you very much.
