- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All
Any advise please, I have updated to Inventor 2022 and I am having an issue with the default IBL with my templates. (I am quite new to this so apologies if its something obvious)
Issue is that the Default IBL show components Black (Very Dark) within the default templates? I have compared with previous templates & the IBL default in my 2021 sheet metal template had an 'Environment tab' as attached image 001, with the lighting tab & shadows next to it, lighting set with 'no' lights on (image 002) all was fine as the part display, nice grey generic material etc... as you can see in the image.
The Default templates IBL in 2022 is missing the Environment tab? Just Lighting & Shadow tabs, with the lighting off as previously settings (image 003) parts show very dark?
When opening my older templates in 2022 I got the Style Conflict popup regarding the IBL, I have opened my sheet metal template & save the Default IBL to the style library and all seems good opening the template from 'New' until I open a different part template , expecting a style conflict because this hasn't been updated, but No it seems to reset style Library back to the 2022 default (Very Dark), going back to my sheet metal template I then get the Style conflict again?
The problem in summary is how do I get the lighting back to how it was so I can see the component material & appearance other than black / dark?
Additionally is the environments tab missing 2022 IBL style correct, part of the problem? Finally whey does my Save IBL Style from my previous template revert to showing 'Style Conflict' opening a 2022 default template.
Hope this makes some sense, any assistance appreciated,
Regards
