Is it just my imagination or what? I updated my inventor 2021 to 3.1 and now it seems I have to click in the window before I can do anything. Seems different I've been using Inventor for 19 years and I don't think I ever had to do this? Even closing one tab in Inventor I have to then click on the screen before I can work on it.
by the way I'm using windows 10.
thanks
Solved by slphantom. Go to Solution.
Hi Scott,
I am not aware of the issue. Did you update your Space Explorer's driver?
Many thanks!
I'm on 2020.4 and have the same issue.
Quite annoying. Just switched to a new pc and can't remember if I had the issue before though.
Hi Folks,
This may not be Inventor related. Try this Go to Windows Mouse Pointer option -> Change touch feedback -> turn it off.
Many thanks!
So it was not the Inventor 2021 update that did it it was the windows security update that did it. I uninstalled the update and everything is back to normal.
