Error Connecting between SSD and Autodesk Inventor 2016
Message 1 of 8
I replaced HDD with SSD but after this change there are some issue with my PC/Autodesk Inventor (2016):
1: Some times, it show blue screen (Your PC ran into Some issue).
2: When i restart PC, it appears on screen (No Bootable Devices).
3: When, i open Autodesk Inventor (2016) it crashed many many times, (Your PC ran into Some issue).
4: When, there are heavy files in Autodesk Inventor (2016), it starts buffing and takes too much time.
5: Autodesk Inventor (2016) works fast on single PC but when PC connects as a domian, inventor works very slow and command execution times increased as compared to single user PC.
My email Account is : private
Need Help and suggesions her or anyone can contact my Gmail account
Q1: Is this an issue of PC or SSD?
Q2: Is there compatibility issue of Autodesk Inventor (2016) with SSD?
Q3: Kindly give my best solution/suggesion for this issue.
Replies (7)
Message 2 of 8
the first 3 should have told you its not an Autodesk or Inventor issue
take your machine to a repair shop for them to troubleshoot the issue if you don't know how
Message 3 of 8
bradeneuropeArthur
How have you installed the new SSD?
Have you created an image from the Drive and Installed that image?
Have you had some errors during installing the image?
What else have you changed within the machine?
Seems that this is not Autodesk related.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 8
johnsonshiue
Hi! I have removed your email address from the original posting to preserve user privacy.
How much system RAM do you have? It sounds like the machine runs out of RAM and starts using Swap memory.
Many thanks!
Software Test Engineer
Message 5 of 8
16 GB RAM
Message 6 of 8
First (3) issues just happens when, i use Inventor. Otherwise, PC is working perfectly.
Message 7 of 8
bradeneuropeArthur
Have you tried "Repair Inventor"?
Have you tried "Reinstall Inventor"?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
johnsonshiue
Hi! Please make sure all critical Windows updates are installed and graphics driver is updated. Make sure 2016 service packs are installed.
https://knowledge.autodesk.com/support/inventor/downloads/caas/downloads/content/autodesk-inventor-2...
Many thanks!
