inventor 2020
inventor 2020
inventor 2020
Indeed, I've tried Inventor 2020, but I found that the contrast of the looking of the lines are very weak especially the construction lines where it is very hard to distinguish, also the fonts of the writing and the numbers are small and I couldn't enlarge them even by zooming. Is there a way to make them to be seen easily before I refusing it  because the older versions are very clear.
wish you good day
likemohan
You can always go through your application options if you don't find you like the current color scheme and change it to something else you may like better (image attached).
As for text height, this depends on what you're referring to specifically. There's likely a way to change the text height you're referring to, but the method could differ depending on the specifics.
If I'm being honest, I'm not sure that I've seen any text height changes over the years of using the software and I upgrade ever year. Is there a way to provide an example of what you're accustomed to seeing on screen versus what you see now?
Thank you,
My image didn't attach. It is attached to this reply.
And for any autodesk members reading, the post editor seems to be bugged for some reason. It will allow me to edit my post, but it won't allow me to post my edits. Not sure if that's on my end or not.
andrewiv
For the first issue, can you provide a screenshot of what you're seeing?  This is what the construction lines look like for me.
For the second issue, you can adjust the size of the on screen text by going into the application options and changing the annotation scale on the General tab.  I have mine set to 2 so that the text is a little bit larger.
Andrew In’t Veld
Designer / CAD Administrator
johnsonshiue
Hi! This could be related to the DPI setting. Go to Windows Display Settings and change DPI to a bigger value.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Thank you for your message and your solution for the second issue.
Here is a screenshot for the first issue where the strength of the construction lines is very weak and I appreciate your solution. I'm using now a black back ground or the high contrast.
Thank you,
Mohan
