Inventor 2020 Stress Analysis
sashalmidavid1992
Message 1 of 12
sashalmidavid1992
I cannot use the Stress Analysis application in iInventor 2020. Its icon doesn'a appear in the part module. What can I do?
Replies (11)
Message 2 of 12
yalcon7XU75
You should see the option in the 3D Model tab or
the Manage tab. If this is not the case and you are in a hurry,
take the component to an assembly and there you
should have the stress analysis. On the other hand, it would be reinstalling the program
in a different version than the one you have.
Message 3 of 12
JDMather
@sashalmidavid1992
Can you post screen shot of what you see.
Also screen shot of your version of Inventor properties (including Update number).
And, the actual *.ipt file.
Message 4 of 12
sashalmidavid1992
Dear JDMather!
Here are some screen shots.
Message 5 of 12
admaiora
Did you check this?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 6 of 12
sashalmidavid1992
Yes I did. The Simulation cannot be found in that list.
Message 7 of 12
johnsonshiue
Hi! I was wondering if it could be Inventor, not Inventor Pro. But the Stress Analysis Add-In is indeed there (loaded). I guess the only thing to try is to force Inventor to load all dlls on startup. Go to Control Panel -> System -> Advanced System Settings -> Environment Variables -> create "DYNAMIC_LOAD_APPLETS" and set it to 0.
Restart Inventor. Does it work better now?
Many thanks!
Software Test Engineer
Message 8 of 12
sashalmidavid1992
I did what you wrote, but I still cannot find Stress Analysis. What do you mean about Restart Inventor? Maybe to install again?
Message 9 of 12
JDMather
@sashalmidavid1992
Can you go to About Inventor
and post screenshot similar to below...
I am running 2024, but your screen should be similar with 2020.
I notice from your screenshot that your screen is missing the word Professional...
Message 10 of 12
sashalmidavid1992
Message 11 of 12
johnsonshiue
Hi! You installed Inventor 2020, not Inventor Pro 2020. Please uninstall Inventor 2020 and run the install again -> select Inventor Pro 2020.
Many thanks!
Message 12 of 12
sashalmidavid1992
Allright. I've downloaded Inventor PRO 2021.
Thank you very much!
