Inventor 2020 (RTM & 2020.0.1) - Bug – Factory /Member Scope Disabled
MattH_Work
Advisor Advisor
MattH_Work
In my Inventor (patched, then as an experiment unpatched) the Factory / Member scope drop down is disabled for both Non iParts & iParts/iAssemblies. On a colleague’s Inventor 2020 PC it is enabled at all times and therefore actually useable. Using 2018/2019 onm my PC the drop down is enabled at all times.
MattH
Product Design Collection 2027
Vault Pro 2027
MattH_Work
Off the back of another issue with Inventor 2017 & 2018 (see https://forums.autodesk.com/t5/inventor-forum/windows-version-1903-and-inventor-2018-issues/td-p/881...) I think this issue may stem from my recent update to Windows 10 1903 which updates Dot Net to version 4.8. ALL current versions of Inventor are built on previous Dot Net versions
Can someone at Autodesk do some testing?
MattH
Vault Pro 2027
MattH_Work
Inventor Reset Utility
C:\Program Files\Autodesk\Inventor 2020\Bin\Inventor.exe /install
C:\Program Files\Autodesk\Inventor 2020\Bin\Inventor.exe /register
Still an issue
MattH
Vault Pro 2027
johnsonshiue
Hi! The behavior does not look right to me. I will work with the project team to understand it better. The commands should always enabled.
Many thanks!
Software Test Engineer
deoriodp
how can this be resolved?  unable to swap between factory/member nor able to generate
johnsonshiue
Hi! It has been three years since my last reply. I don't recall what was the outcome. Please share your files (zipped) here or send it to me directly [email protected]. I would like to understand the behavior better.
Many thanks!
A.Acheson
Hi @johnsonshiue this is still an issue in the latest 2020 releases. It happens in my case when I use the addin Tube and pipe in normal use. After activating any  tube and pipe document the member scopes will become grayed out.
I have an ilogic button set up to activate the scope otherwise it would be a close inventor and reopen to resolve the issue.
https://forums.autodesk.com/t5/inventor-forum/inventor-2020-release-2020-3-bugs-factory-member-scope...
Regards
Alan
