Inventor 2020.1 update was released last week. Check your Autodesk Account or the Autodesk Desktop App for your update.
What’ New and release notes here:
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-DE1C5290-0115-4D81-A7AF-5B7B9B769E4E
Solved by johnsonshiue. Go to Solution.
Hi Scott,
None of these behaviors are normal. There is a company-wide licensing issue which could cause behaviors like this. Please install the licensing patch. Then install 2020.1 update.
Please report back your findings.
Many thanks!
Hi Johnson,
Always a pleasure to hear from you. Yes, you are right, there is nothing normal about this sequence of events.😯 I only worked half day yesterday and that was spent trying to right this issue.
This morning I did what you suggested. Installed the patch and then 2020.1
Then I restarted and it proceeded to install the same Windows update that started this whole thing yesterday. That took about 45 minutes. And again like yesterday, Inventor cannot connect with Vault after the update.
Like I said yesterday, this has happened to me one other time. So, I am going to revert back to the previous build of windows and I will assume that all will be good. The good news is my Inventor seems to be working again and I can see my iLogic browser again.
I will give you a final report after I uninstall this Windows update.
I have since reverted back to the previous version of Windows and everything appears to be working just fine again.
As Always Johnson, Thank you for your diligence and support on these forums!!!
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Small feedback on the update, It's a small thing but I'm not partial to the bold text that the iProperty was changed to. The fields are all 3D boxes now, which I couldn't care less about, makes no difference to me but I uninstalled the update because of the bold text.
Sure wonder why some of these changes are implemented...
I'll wait for another update and see if it affects me or not. Usually I want to keep current but the bold text just hurts my eyes so I'll avoid it as long as I can.
John
Can you share a screen shot of the issue you're referring to?
Meaning I don't know which bold text you are talking about that's hurting your eyes, so a screen shot could help understanding this...
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi Mark,
Thanks for the reply but I've uninstalled the update so I can't send you a screenshot of the bold text. But, it was in every field except for the date field. I'm guessing whichever field was changed to the 3D also was changed to bold. The date field was still flat so it wasn't bold.
If it will help, I'll install the update again so I can show you the issue.
John
Are you talking about the iProperties dialog box?
Mark Lancaster
You did, but then you were talking about the date field so I wasn't sure if you were talking about the iproperies box or something else because date fields are pull-down and not edit fields in the iprop dialog.
Anyhow not seeing any bold lettering but perhaps you view it a different way....
In the end was just trying to understand what you were seeing.
Mark Lancaster
Sorry, Mark, I wasn't trying to be difficult.
Here's a screenshot that shows the bold text in the property fields. You can also see that the date field is not in bold because it's not a customizable field, just a selectable field.
Also, note that the file subtype field is not bolded because the field is not in 3D format. If I were to add screenshots of the various iProperty dialog box, the same rule applies to the different fields. Anything that has been changed to have 3D box around the field has had the text changed to bold, anything that is still "flat" is normal text.
Appreciate your interest, hopefully someone from ADesk can comment.
Not seeing that all at my end..
Under Tools/Application Options/General tab, what do you have for text appearance?
Just to confirm, when you don't have the 2020.1 update, the info (text) is not bold?
Mark Lancaster
My text appearance is Tahoma 8 pt, which I believe is default. And, yes if I uninstall the update the text goes back to normal.
