Inventor 2019 part window minimized
Jwm9765
Jwm9765
Community Visitor
Community Visitor
I have Inventor Pro 2019 on an education licence. Everytime I open a new part, it has the minimized window view. While this is not a big problem, it annoys me to all ends.
i am running it on Windows 10 version 1803 64 bit
mcgyvr
Close Inventor..
Right click on its icon and select "run as administrator"..
Then open a part and if its minimized expand it then open another part.. Is that part minimized now? or is it fixed?
It should be as simple as maximizing then it retains that setting.. If its not doing that it may indicate improper permissions to right to the registry..
If permissions are correct then you may want to try running the Inventor Reset Utility that is in the AUtodesk folder of your start menu.. (backup your application options first) Did that help?
johnsonshiue
Hi! I have not seen this behavior before. Try something real quick. Go to All Programs -> Autodesk -> Inventor 2019 -> Tools -> Inventor Rest Utility -> set 2019.
Many thanks!
Software Test Engineer
