Inventor 2019.2 Update Error with Copy Design
ferrisb
Message 1 of 134
ferrisb
This morning I installed update 2019.2 on a Windows 10 workstation.
Now my copy design from Vault does not work.
Can anyone else reproduce this or, possibly know the solution?
For now I just uninstalled that update, and it works as normal.
Replies (133)
Message 21 of 134
JamesMcMullen
I just tried a vault user that was a "Consumer" and "Editor 1".  Both of those worked without issue.  Are you referring to making the users a "Windows Administrator"?  Also, below is a Screencast link showing what I am doing on my image to reproduce the issue.  I know the user is logged in as an administrator for the video but as mentioned I tested it without the (Vault) administrator user permission.  You may need a Screencast account to see the video:
https://autode.sk/2DuV02x
James McMullen
Principal SQA Eng.
Message 22 of 134
We found that it depends on the level the User has in Vault - We have changed the User to Administrator.   They then can use copy design...   This is not a Solution!!!!
Users have local Admin Priv in windows on their PC - Normally in Vault they have “Document editor level 2”
On One PC Windows 10 (1803) (INV 2019.2/ BasicVault 2019.1)
   - We had two different users log in.
  - Only ran Vault for both User.....
  - The Vault Admin - Copy design works fine
  - The Edit2 user - Copy design does not work.
Message 23 of 134
scottmoyse
Ohh that's a good clue. I bet a lot of the testing that's being done to repro this is with Administrator Vault accounts
Scott Moyse
Did your question get successfully answered? Please accept the post as a Solution to help others find it.
CAM Consultant and owner at Nominal Systems. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 24 of 134
ihayesjr
Hi Dana,
I have also tried this and I am unable to reproduce the error you are seeing. Please log a product support case so that someone can remotely connect to investigate the issue.
While you wait for the support case, try running a repair on the Vault client and Inventor View and trying again.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 25 of 134
andy-axium
I am a vault administrator and I am getting the Copy Design Error
Message 26 of 134
andy-axium
please see screencast
Message 27 of 134
ihayesjr
Please try and run a repair on the Vault client, Inventor and Inventor View applications. Do them one at a time and test again after each repair.
Irvin Hayes Jr
Autodesk, Inc.
Message 28 of 134
andy-axium
I've tried a repair on both Vault Basic and Inventor 2019.2, can't see a way of doing a repair on Inventor Viewer.
Didn't make any difference.
Screenshot showing Vault profile also attached.
Message 29 of 134
ihayesjr
Can you uninstall Inventor View and reinstall it from the Vault client installer?
Irvin Hayes Jr
Autodesk, Inc.
Message 30 of 134
andy-axium
Hi Irvin,
Possible if I knew how?
Can't find an uninstaller for I View?
Message 31 of 134
ihayesjr
Try reinstalling from the Vault client please.
Irvin Hayes Jr
Autodesk, Inc.
Message 32 of 134
andy-axium
I do have Inventor View installed, I can see it in the programs list but it is not in the add/remove programs in control panel?
Can't seem to unistall?
Message 33 of 134
andy-axium
Possibly a stupid question, but how do you uninstall Inventor View when it's
not listed in add/remove programs?
Message 34 of 134
scottmoyse
The Autodesk uninstall tool in your start menu?
Scott Moyse
Message 35 of 134
andy-axium
No uninstall option in the uninstall tool for Inventor View?
Message 36 of 134
eric.roades
We were having the same issue yesterday with the Copy Design feature, and it seemed to extend to the "View in Window..."  tool also.  At some time yesterday, an update for the Autodesk Desktop App came up.  I installed it, rebooted the computer, and Copy Design and View in Window seem to be working again.
I've done this on three workstations with the same results: Copy Design gave the "error occurred during file operations" mesage, and View in Window just didn't work prior to the Desktop App update, and even after the update was applied.  Rebooting the machine after the update, and these are functional again.
I hope that this can help others that are having this issue.
Message 37 of 134
scottmoyse
Which program was the update for?
Scott Moyse
Message 38 of 134
eric.roades
The update was for the Autodesk Desktop App itself.  I wouldn't figure that would have anything to do with Copy Design, but that's the only thing that's changed between yesterday and today.
Message 39 of 134
ihayesjr
Can those who are still having issues can you try and go to C:\Program Files\Autodesk\Inventor 2019\Bin and double-click on InventorView.exe so it runs? Then see if you get the error.
Irvin Hayes Jr
Autodesk, Inc.
Message 40 of 134
We have found that stations that have this problem will autoMagically fix themselves and start working !!!!!!!!! No intervention other than daily booting/shutdown
We had an Interactive session with AutoDesk Yesterday and - low and behold - All work as it should - While they were connected!!!! As soon as we rebooted after the session - Copy Design No Longer Works!
We have also found (as expected) if we uninstall the 2019.2 patch - All works as expected....
We have another session with Autodesk today - I'll try and Post the results......
