Hi
I'm using Inventor 2018. i have created a part which do not have any surfaces in it.(see ipt,ipt2)
when i tried to create drawing out of it, i could not see the view. (see drw).
please help me out on this.
Thanks in Advance
kelly.young has embedded your image and edited your subject line for clarity: part not visible in drawing
My suggestion would be to edit that view, go to the view tab and turn on tangent edges.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Hi! This is a bug I believe. Please attach the file here so I can follow up with the project team and see what we can do. In the meantime, you can try a trick to see if it works better. Use Split command and select the origin plane passing the seam edge and split the faces. I believe the views will be displayed correctly.
Many thanks!
In the Edit Drawing View Window, there's a 4th tab called Recover Options, under that are boxes for Including Surface Bodies and/or Mesh Bodies. See if either of those work. If not, try looking in the Drawing Browser and make the part visible there instead of in the model itself.
Philip Martick
Inventor 2018 Pro, AutoCAD 2018, Autodesk Vault Basic 2018
Windows 10 Pro
2X Intel Xeon E5-2630 v4 @ 2.20GHz
16.00 GB of RAM
NVIDIA Quadro M2000
