Inventor 2018 FEA Convergence plot not working
corneUCBK6
corneUCBK6
Hi Guys,
I am having a bit of trouble with the convergence plot.
Setting the convergence settings and the convergence plot seem all to be running ok in a normal simulation.
However when I use the selection to exclude components the refinement does not seem to work and the convergence plot is greyed out or does not update.
Is this what you expect to happen or is it an error in the software?
The reason I try to exclude geometry is because the stress is jumping across the symmetry (mirror) side of the assembly and screwing up my refinement/convergence plot.
Cheers
Corné
corneUCBK6
Hi guys,
Could somebody please run a simulation in 2018 and exclude some faces from your model and see if the convergence plot works? So i know if it is a software limitation issue or a local issue?
Much appreciated
Corné
inchul.lee
Autodesk Support
Autodesk Support
Please feel free to share your model or some screenshots so that we can have a better idea of what you're experiencing. If the data is confidential, you can also direct message me to share.
Inchul Lee
Binga
Hello.
It is working well here.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
corneUCBK6
Thank you for your reply.
I have lodged my error with our Autodesk software provider in NZ and they confirmed the same error and have send it on to Autodesk Support. But so far no reply. Interesting to see that it works well for you.
Cheers
Corné
