Export 3D Points to Excel Inventor 2016
Hello Autodesk Community,
I've recently came up with the Problem of exporting 3D Points from the Assembly Document into an Excel Document in Inventor 2016. A Solution given for Inventor 2011, where I edit a VBA Document, doesn't work for this Version. Hope anyone got a Solution.
Best regards,
Oliver Kuschka
johnsonshiue
Hi Oliver,
Here is a similar request on Inventor Customization forum. Please take a look at the solution.
https://forums.autodesk.com/t5/inventor-customization/unable-to-export-3d-point-co-ordinates-data-to...
Many thanks!
Software Test Engineer
salariua
is this the solution you mention?
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Hi Adrian,
yes that was the solution I found. The Vba Codes didn't work for me. But I already got a solution from Mr. Shiue. Thanks for helping!
Hello Mr. Shiue,
Thanks for helping. This solution worked for me!
Best regards,
Oliver Kuschka
