Inventor 2018 Bug: Automatic Select Other Drop Down Missing For Plane Axis Point
andrewiv
Mentor Mentor
Message 1 of 9
andrewiv
When trying to create a work feature in 2018.2 the automatic select other does not work.  You can still right click and use select other, but the drop down will not pop up on its own.  It works fine with other features like the hole command, but not with planes, axis, or points.  It happens in both part and assembly environments.
kelly.young has edited your subject line for clarity: Select other bug
Andrew In’t Veld
Designer / CAD Administrator
Replies (8)
Message 2 of 9
mcgyvr
I see the same issue..
Message 3 of 9
kelly.young
Autodesk Support
Autodesk Support
@andrewiv thanks for posting. Sent to the development team for further review. Will post back with any information I find.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 4 of 9
johnsonshiue
Hi Andrew,
I am able to reproduce the behavior. I don't have a good explanation. It looks like a bug to me. I will work with project team to understand it better.
Many thanks!
Software Test Engineer
Message 5 of 9
Xun.Zhang
@andrewiv@mcgyvr,
I checked with Inventor 2016, 2017 and 2018, the behavior is the same, It seems nothing changed when creating workfeature, the select other context menu is always hide.
Could you help confirm?
Thanks!
Xun
Message 6 of 9
mcgyvr
@Xun.Zhang wrote:
@andrewiv@mcgyvr,
Thanks!
Ok... so its been a bug for 3 years and someone finally noticed it..
Message 7 of 9
Xun.Zhang
@mcgyvr,
I am sorry for that.
Ticket INVGEN-12065 was open to track it down.
Thank you as usual!
Xun
Message 8 of 9
diego_dorta
sad to say that I have the same problem with Inventor 2024.3!!
CTRL+A works fine but the automatic scroll down menu doesn't show after the seconds set in the application option
Message 9 of 9
johnsonshiue
Hi Diego,
I am not sure if your issue is the same as the OP's. If you are looking for Autoscroll option, it is located in upper right corner of the browser. Click on the three-bar menu -> check Autoscroll.
Many thanks!
